90
General Reporting Questions
1. Shared Report Headers - Is it possible to design a report header that can be used by all reports within an application. At the moment i am having to copy and paste the report header onto each report i make.
2. Formatting Data - Is it possilbe, to format labels so that they always show data to the same number of decimal places. For ecample i have a dataset with a field Amount, how can i have a Summary of the Amount fields showing the result to 2 decimal places. I have seen the string Format in the expression assistant, but have not been able to combine it with a Sum function.
3.Printer Orientation - No matter which orientation you set when designing a report, when printing you always have to manually change the printer settings so that the paper orientation matches the report being viewed. Is this something that will be addressed in a future release, if so is there an eta on when it will be fixed. Are there any work arounds for this problem?
