60
Row detail
HI, i have an entity that contains the name, hire date and annotations about employes. I need to display just name and hire date in columns and when the row is selected, i need to show - as detail row - annotations. how can i do that??
Thanks!
  • 40030
    We don't have the concept of a DetailsRow specifically, however, i believe you can use our TemplateColumnLayout feature and a little code to achieve what you're looking for.
    1. Take a look at this sample:
    http://samples.infragistics.com/sllob/RunSamples.aspx?cn=grid#/grid/template-column-layout
    2. Turn off  Expansion Indicators
      <ig:XamGrid.ExpansionIndicatorSettings>
                        <ig:ExpansionIndicatorSettings Visibility="Collapsed"/>
                    </ig:XamGrid.ExpansionIndicatorSettings>
    3. Handle the ActiveCellChanging event to look something like:
     private void grid1_ActiveCellChanging(object sender, ActiveCellChangingEventArgs e)
                if (e.NewActiveCell != null)
                    if (e.PreviousActiveCell != null)
                        if (e.PreviousActiveCell.Row != e.NewActiveCell.Row)
                            Row r = e.PreviousActiveCell.Row as Row;
                            if (r != null)
                                r.IsExpanded = false;
                    Row r = e.NewActiveCell.Row as Row;
                    if (r != null)
                        r.IsExpanded = true;
                else if (e.PreviousActiveCell != null)
                    if (r != null)
    Hope this helps,
    -SteveZ
