Whenever I try to run a program, even the SampleBrowser, I just get a white screen with "Loading" and it never starts up. If I then set the shell back to default it works fine. The Themes work, but the shell causes programs not to load. Any solution for this ?
I am just checking if you had a chance to try out Anatoli’s suggestion and if this is still an issue for you.
Please let me know if you require any further assistance on the matter.
Оur extensions are built for LightSwitch RTM, so installing it should resolve this issue.
Best regards,
Anatoli
Still on Beta 2 at the moment.
Hi
Can you please tell us which version of the LightSwitch IDE you use?
