Hello everybody,
I am looking for a quick how-to which provides insight on enabling the grid for Cube Writeback. My cube is definitly writeback-enabled and I set all reasonable properties on the grid.
<igPivot:XamPivotGrid x:Name="pivotGrid" Loaded="pivotGrid_Loaded" DataSource="{StaticResource adomdDataSource}" AllowHeaderRowsSorting="True" AllowHeaderColumnsSorting="True" AllowDrop="True" AllowHiddingColumns="True" AllowHiddingRows="True" IsManipulationEnabled="True"> <igPivot:XamPivotGrid.EditSettings> <igPivot:EditSettings AllowCellEdit="True" EditFormatedValue="True" > </igPivot:EditSettings> </igPivot:XamPivotGrid.EditSettings> </igPivot:XamPivotGrid> <igPivot:Expander Grid.Column="1"> <igPivot:XamPivotDataSelector x:Name="dataSelector" DataSource="{StaticResource adomdDataSource}" /> </igPivot:Expander>
Setting the EditableMeasure collection happens in the Loaded event of the grid.
private void pivotGrid_Loaded(object sender, RoutedEventArgs e) { foreach (Infragistics.Olap.Data.IMeasure item in pivotGrid.DataSource.Cube.Measures.ToList()) { this.pivotGrid.EditSettings.EditableMeasures.Add(item); } }
Is there anything else I need to do/know in order to enable cube writeback in the pivotgrid?
Looking forward to your suggestions.
HI,
I am just following up on this forum post.
Please let me know if you need further assistance.
Sincerely, Matt DSE
Here is a forum post addressing your issue:
http://community.infragistics.com/forums/t/58511.aspx
