Hello everyone, I met a problem trying to get selected row on postbackScenario is pretty simple.I create UpdatePanel and WebDataGrid in CreateChildControlsprotected override void CreateChildControls(){ base.CreateChildControls(); UpdatePanel container = new UpdatePanel{ ID = "c", ChildrenAsTriggers = true}; this.Controls.Add(container); this.grid1 = new WebDataGrid { ID = "grid1", EnableAjax = false, EnableAjaxViewState = false, EnableViewState = false }; container.ContentTemplateContainer.Controls.Add(this.grid1); this.grid1.Behaviors.Add(new Selection { RowSelectType = SelectType.Single, CellClickAction = CellClickAction.Row, Enabled = true }); this.grid1.RowSelectionChanged += Selection_RowSelectionChanged; this.grid1.Behaviors.Selection.RowSelectionChanged += Selection_RowSelectionChanged; this.grid1.Behaviors.Selection.AutoPostBackFlags.RowSelectionChanged = true;}void Selection_RowSelectionChanged(object sender, SelectedRowEventArgs e){ throw new NotImplementedException();}Then I add columns and populate grid with data from my datasetprotected void Page_Load(object sender, EventArgs e){ DataSet ds = new DataSet(); ds.ReadXml("c:\\q.xml", XmlReadMode.ReadSchema);... Add several columns here this.grid1.DataSource = ds; this.grid1.DataBind();}Postbacks occur correctly on every mouse click and selected row index is passed in grid1_clientState parameter (bold) [[null,[[[[[5]],[],null],[null,null],[null]],[[null,[],null],[{},[{}]],null],[[null,[],null],[{"1":[6,[{"index":1,"key":[1]}]]}But none of RowSelectionChanged evens is fired.Can anyone say what is wrong? Is it affected by the time grid is populated with data? What is the right time to populate then?Maybe some settings/options/flags are missing?Version I'm using: 10.3 SR2120 for ASP.Net
Hi Andrey,
I have attended to your question in this topic:
http://community.infragistics.com/forums/t/58602.aspx
Please refer to the above thread.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
