Around June 29, I downloaded and installed Infragistics NetAdvantage Reporting Version 11.1.268. Today I decided I would finally check it out.
I created a class library project, created a simple data source, dragged the datasource on to the report design surface and everything appreared OK.
Attempted to preview and the following error occurred:
An unknown error occurred while processing the report.
I chose to view the details and the following is all the details that were displayed.
at Infragistics.Controls.Reports.ProcessingSessionStateMachine.CreateProcessor(IRenderingEngineFactory renderingEngineFactory) at Infragistics.Controls.Reports.ViewerStateMachine.Render(Boolean firstRender, IDictionary`2 selectedParameterValues)
Any suggestions to go forward from here? I am using Visual Studio 2010, SP 1 running on XP SP 3.
As this issue occured using the CTP version of the reporting tool. Please let me know if you are seeing this issue now that the RTM version has been released.
Sincerely,ValerieDeveloper Support Engineer Infragisticswww.infragistics.com/support
It was a sql data source. I am not working in SL.
When I try the samples installed with the product, I experience the same problem.
Did you create a SQL Data Source or an Object Data Source? Are you working in SL?
Did you try the samples installed with the product? Did they work or are you experiencing the same problem?
Leo
