165
How to get dropdownlist object from UltrWebGrid Cell?
I am using NET Advantage 2008 CLR 2.0 version.
I have a standard "dropdownlist" column in my UltraWebGrid, now I will like to extract the dropdownlist object from my UltraWebGrid.
Given I have the row and col index of my cell. How can I do that??
My objective is to get the dropdownlist selected item's datamember. Doing a
uwg.Rows[rowindex].Cells.[colindex].Value
simply only gives me the displaymember of the dropdownlist, which is not what I want.
Please shred some light onto this. Thank you!
Chinho
  • 49378
    Hi Chinho,
    If you are using a column which is of type DropDownList then there is no actual Dropdownlist object to be accessed.However, you should be able to match the Value of your cell (DisplayedValue) with the Datamember in your ValueListItems collections which can be accessed by:
    UltraWebGrid1.Columns[2].ValueList.ValueListItems
    In case you are using a templated column with a dropdown list, you would be able to directly access the Dropdownlist object inside the template. Detailed instructions on how to achieve this are available at:
    http://forums.infragistics.com/forums/t/26392.aspx
    Please tell me if this helps.
    Best Regards,
    Petar Ivanov
    Developer Support Engineer
    Infragistics, Inc.
