Is it possible to get an Italian dictionary for the WebSpellChecker control (2011 vol. 1 version)?
The LanguageParser property allows the "Italian" value, but I wasn't able to find the .DICT file for the italian language.
Thanks in advance.
Pier Alberto
Thank you Petar for your answer.
I will try to develop an italian dictionary.
Hi Pier,
I am following up to check whether you have any more questions. Please do not hesitate to contact me if you need further assistance.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
The WebSpellChecker does not currently come with an Italian dictionary, however you can develop a dictionary by using the structure of the other Infragistics .dict files.
A detailed guide presenting how to specify a dictionary file for the WebSpellChecker can be found at:
http://help.infragistics.com/Help/NetAdvantage/ASPNET/2010.3/CLR4.0/html/WebSpellChecker_Specify_a_Different_Dictionary_for_WebSpellChecker.html
Please tell me if this helps.
