I have added panel to my page. Within which I have added a UltraWebGrid. This UltraWebGrid has 22 columns, so it doesn't fit inside the panel. I added a horizontal scrollbar but it is not working. It is still going out of the panel.
Can you please provide some input? I am new to this.
check the width of the panel and grid.
check below properties of the ultraweb grid.
ScrollBarView
="Both" ScrollBar="Always"
TableLayout
="Fixed"
UseFixedHeaders="True"
if you want to fix the header of few of the columns then add the below line of code in your grid initializelayout event. the below code will fix your first four columns in the grid.
e.Layout.Bands[0].Columns[0].Header.Fixed = true; e.Layout.Bands[0].Columns[1].Header.Fixed = true; e.Layout.Bands[0].Columns[2].Header.Fixed = true; e.Layout.Bands[0].Columns[3].Header.Fixed = true;
