I have the following:
<ig:XamDialogWindow x:Name="dlgAddReport" Grid.Row="0" RestrictInContainer="True" IsResizable="True" IsMoveable="True" Header="Add Report" IsModal="True" CloseButtonVisibility="Collapsed" MaximizeButtonVisibility="Collapsed" MinimizeButtonVisibility="Collapsed" HeaderIconVisibility="Collapsed" StartupPosition="Center">
<ig:XamComboEditor Grid.Column="1" Grid.Row="1" Width="200" Margin="10,0,0,2" IsEditable="True" DisplayMemberPath="ReportDesc" ItemsSource="{Binding ReportDetails}" SelectedItem="{Binding SelectedReportDetail, Mode=TwoWay}" /> </ig:XamDialogWindow>
When I load the page I get the following error:
The type 'XamComboEditor' was not found.
Info:
InfragisticsSL4.Controls.Interactions.XamDialogWindow.v11.1.dll
11.1.20111.1004
InfragisticsSL4.Controls.Editors.XamComboEditor.v11.1.dll
If the above suggestion helped you solve your issue please verify the thread as answered so other users may take better advantage of it.
I have been looking into this for you and it appears you have forgotten the InfragisticsSL4.v11.1.ddl file. Also I can suggest using our predefined namespace: xmlns:ig="http://schemas.infragistics.com/xaml"
I have attached a sample project with all that for your reference (SilverlightApplication1.zip).
Please let me know if I can be of any further assistance on the matter.
Just a quick update,
I change my xmlns and now I get the following error:
The type 'XamComboEditor' was not found because 'clr-namespace:Infragistics.Controls.Editors;assembly=InfragisticsSL4.Controls.Editors.XamComboEditor.v11.1' is an unknown namespace.
