1590
Want to eliminate few column values while calculating column Sum in xamgrid
My application have summary report which is binded to the XamGrid. In the Grid SummaryRowSettings is enabled. In report resultset in between few rows will be having SUM value. Which i want to eliminate while calculating the sum. But now when i click on SUM of any grid column its getting the sum of all the records which is actually wrong in my case.
So could you please provide a sample which shows the Summary operations are calculated manually through the service. Please suggest if there is any other alternative. It is high priority for me. if possible attach  the sample.
Anil Kumar
