Someone know how to create a floating tool pane like this?
http://samples.infragistics.com/sldv/RunSamples.aspx?cn=data-chart#/data-chart/binding-live-data
I'm searching for some examples
I would use it to contain the legend so it can be moveable and mininizable
Thanks in advance
thanks for the answer, I found the source code!
but... how do I create the graphical control?
Do you have the samples installed on your machine? You should be able to examine their source code for the implementation of the floating tool pane you see there.
-Graham
