Recently our company migrated from windows XP and IE8 to Windows7 and IE9. I've begun to notice problems with the editing in our webgrids. They fill in a text and then press a button to process the grid, but the text is not saved. Also if they edit a text in one line of the grid, they cannot select the same field in another line to edit that one.
We've installed the netAdvantage web client : ASP 2008 Vol 3. CLR 2.0 on our server.
Thanks for your feedback.
I've just upgraded to Netadvantage for .Net 2011 Vol 1. Initial tests seem positive. I am cautiously optimistic. Will Verify this answer when further tests have been concluded
Hello Dirk,
Thank you for posting on our forums. I highly recommend upgrade to newer version since NetAdvantage for ASP.NET Vol. 3 indeed does not support IE 9.
Please have a look at the supported environments page : http://ko.infragistics.com/support/product-lifecycle.aspx#ProductLifecycle
