2254
Can the WARP Panel use request.open("GET", form.action, true); instead of "POST"
I use  Infragistics 2011 Vol. 1. By checking the file below:
C:\Program Files\Infragistics\NetAdvantage 2011.1\ASP.NET\CLR2.0\Scripts\ig_shared.js,
I see this function call: request.open('POST', form.action, true);
The question is: Is there a means to replace this POST call with a GET call, like this ?
  request.open('GET', form.action, true); ?
I refresh the panel using the warp.refresh() method; I see internally that this is implemented like this:
o.refresh = function()
{ try{
ig_all._ig_cbManager.addCallBack(this, this._uniqueID, this._element, -1); }catch(e){}
Can I use a JavaScript trick to create my own version of the refresh() function, which has access to internal private variables already in place (i.e. do not lose part of the default functionality I would like to keep)
Thank you
