90
Keeping nodes in two trees synched up client side?
I have two webdatatrees that I am using to represent a file system structure of folders and documents that I am using for file move.  Basically, customers who need to move files would select them from the first tree and drop them on the second tree (similar to the Multi Tree sample - including image below).  Both trees represent the same file system so they are identical but I only allow drag from the first tree and only allow nodes to be dropped on the second tree. The webdatatrees remove the selected node and add to the second tree a-ok, but here is the problem:  I need the new folder/file positions reflected in the first tree (currently just removes it) and the old folder/file positions to be removed from the second.
For example:  I drug the Whitesnake folder from the first tree and dropped it in the Y.Malmsteen folder (circled in red) on the right.  The original position of the Whitesnake folder is circled in blue in the second tree -- I would prefer that disappear as well in the second tree and display in the correct folder in the first tree (marked with ??? in blue).  Is there an easy way to do this client side?
