Hi
I have an issue using the XamNumericEditor. As you can see in image below in normal mode, the digits after the comma are hidden. I want the XamNumericEd to show all the value.
When i click in the XamNumericEditor the all the value is hidden, i have to select the value with mouse to see it.
I tried setting the HorizontalContentAlignment but it's not working.
How can i solve this problem ??
I solved setting the DisplayMode property to IncludeLiterals
I have been looking into your issue and have been having some trouble accurately reproducing it on my side. Would you please provide me with your sample project so I can continue investigating the your particular scenario.
Thank you in advance. Looking forward to hearing from you.
