Hi there,
I'm having some trouble adding multiple series to a single chart (line series). Firstly here's an example of the two series data.
Series 1.
Series 2.
Now, my problem is I need to plot both these series on the same chart using LineSeries and making it look like they share the same XAxis (whether behind the scenes they do or not I don't mind).
What I've found doing this is see as the two series have different number of items they must use seperate xAxis, which becomes a problem as I need to only show 1. So the chart should show an XAxis of between 10:00 am and 17:00 pm, with all the items plotted in between over two series.
Can someone please help me with this?
I'm doing the same graph,but in linechart, can u share ur code to me, not the whole code, just the part that how two different range graph to share the same axis.
Actually after some thought about this last night and doing some more investigation I've answered this now. Basically I'm going to create a new X-axis for each series but bind the Max/Min values for the axis which locks the timeframe together.
Being new to this control just takes a little bit to get my head around.
