This is just some information about things we found in our environment.
If you had UltraWebGrid1.DisplayLayout.UseFixedHeaders = True
and used
UltraWebGrid1.Columns(iCol).Header.Caption = "Customer" UltraWebGrid1.Columns(iCol).Header.Fixed = True UltraWebGrid1.Columns(iCol).Width = Unit.Percentage(8)
in the UltraWebGrid1_InitializeLayout Sub
Rendering the page in IE8 compatibility mode would take approx 4 minutes to for a 10 column, 626 row grid. With compatibility mode off the page displayed immediately.
By commenting out or setting UseFixedHeaders to False the grid rendered immediately in both modes.
It seemed like DisplayLayout.UseFixedHeaders = True and Header.Fixed = True together caused the issue.
Within the ASPX code we had to make the following changes:
- Within DisplayLayout.GroupByBox
- Replace the GroupByBox.Style with GroupByBox.BoxStyle
- Within DisplayLayout.Pager
- Replace the Pager.Style with Pager.PagerStyle
- Within DisplayLayout.AddNewBox
- Replace the AddNewBox.Style with AddNewBox.ButtonStyle
- If you are using the GroupByBox
- If you are using the DisplayLayout.Pager.Style
- If the grid is in a container, the grid width should specify less than 100%.
If 100% is used the last column will be truncated.
- Replace:
UltraWebGrid1.Width = Unit.Percentage(100)
with
UltraWebGrid1.Width = Unit.Percentage(98)
This seemed strange but fixed the issue. As I stretched the browser window I could see more of the last column. This made me believe it was some kind of rounding issue on the individual fields in relation to the whole.
For the Excel Exporter we changed the following 2 lines of code:
Dim workbook As Infragistics.Excel.Workbook = New Infragistics.Excel.Workbook()
to
Dim workbook As New Infragistics.Documents.Excel.Workbook()
workbook.ActiveWorksheet = workbook.Worksheets(0)
workbook.WindowOptions.SelectedWorksheet = workbook.Worksheets(0)
Everything seems to be working well using IE8 in both modes.
good luck.....
I've found a better workarount to FORCE IE to not activate the compatibility mode: simply add this in the <head> section of your webpages:
<meta http-equiv="X-UA-Compatible" content="IE=EmulateIE8" />
In my case the performance turned to be normal changing this setting in IE8:Under "Tools" select "Compatibility view settings". Then UNCHECK "Display intranet sites in Compatibility View".It seems that this "Compatibility View" generated Incompatibility...The reason it didn't happen while I was debugging was that it used the Visual Studio ASP.net development server, on my own machine, thus, I wasn't accessing the intranet.I hope it helps.
Hello Adiapps,
Thank you for posting your feedback in our community. Our community members can benefit a lot from this post. Actually IE8 is very slow with tables and the more nested tabled you have in IE8 makes it slower which is browser issue. I am glad that you resolved the issues that you have experienced.
For any further questions and concerns that you have, do not hesitate to contact us.
Sincerely,
Georgi Sashev
Developer Support Engineer
Infragistics, Inc.
