Dear
I'm facing with the problem of xamComboEditor in my Silverlight form. In the form I use ComboEditor as the filter for data source of data form. Everything are ok just only one problem when I click on other tabitem and then click back to tabitem has xamCombo, the xamCombo is set to blank. I try use standard combo of silverlight it has no problem. I also don't have any code for Tabcontrol event.
Please check my attached pictures for reference.
Pic1: Form loaded for the first time, everything ok
Pic2: change to other tabitem.
Pic3: back to the first tabtiem, the problem happen.
Han
Hi Mark,
XamComboEditor is cross-platform component which was ported from SL to WPF so this is the right forum to ask questions about. However XamDataGrid is WPF only control and it will be better to post in its forum(the link I provided in my previous post).
About the issue for xamComboEditor you need to get latest service release which contains the fix for the bug described by Han. If you still experience any issues or difficulties after applying the latest SR please shoot a post here and I'll be glad to assist you further.
I confirmed this issue was fixed in the lasted release.
Thanks Support & Development team.
Didn't realise this was for the Silverlight version since it was found through search, this problem also happens in WPF line of business version, am I better to create a thread there?
the bug in XamComboEditor is fixed in latest(January) Service Release.
About the issue in xamDataGrid you should ask in its forum.
Hope this helps,
Any update on this, we are having the exact same problem (also happens with XamDataGrid if the view is moved away from).
