Hello.
I am using an UltraWebTab and I need to differentiate Tabs. I would like to know if Tab objects can have different appearences. For example some tabs must be in gray background and others in white background.
Hi ocornuau,
I am following up to check whether your issues have been resolved. Please let me know if you have any questions.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
Thank you for the clarification. It should be possible to customize the headers of the tabs client-side. You can handle the InitializeTabs client-side event and get the header element to modify its style. For instance:
igtab_getTabById("UltraWebTab1").Tabs[0].element.style.backgroundColor="Green";
Please tell me if this is helpful.
Thank you for your answer but my question was not verry clear. In fact I wanted to know if it is possible to have different Tab Headers in a UltraWebTab. (customized header of each tab)
Each tab in the UltraWebTab has a Styles collection which can be set individually. For example, to set the BackColor of your first tab at runtime you could use the following code:
UltraWebTab1.Tabs[0].Style.BackColor = YourDesiredColor;
Please note that the styles can also be set at design time. A detailed guide for achieving that is available at:
http://help.infragistics.com/NetAdvantage/ASPNET/2011.1/CLR4.0/?page=WebTab_Set_Styles_at_Design_Time.html
Please tell me if this helps.
