105
How to utilize XmlHTTPResponse
Hi All,
I am exploring the AJAX support in Infragistics at the moment. Can anybody please explain how one can utilize XmlHTTPResponse in XmlHTTPRequestEventHandler method. On the click of a cell in a grid, i need to get an XML from the server and handle it on the client XmlHTTPResponseHandler function. If possible give and example (which lacks in Infragistics online help boo hoo hoo [:'(])
Please help.
Thanks in Advance
-Shikha
  • 25
    This is the result of blood, sweat and tears.  The grid has a templated column with ASP buttons in a column.  I'm handling the click on the client side and using the AJAX call to perform processing asynchronously.  I hope the code is clear and helpful to you, and to others.
    //Server-side stuff
     protected void Grid_InitializeRow(object sender, RowEventArgs e)
        UltraWebGrid stmGrid =  ( UltraWebGrid ) sender;
        printButton.Attributes[ "OnClick" ] = "return PrintStatus( '" + stmGrid.ID + "', " + e.Row.Index + " );";
    protected void DocumentGrid_XmlHTTPRequest( object sender, XmlHTTPRequestEventArgs e )
       if ( e.Type == XmlHTTPRequestType.Custom && e.Data.ToString( ).Contains( "ReportName" ) )
           UltraWebGrid stmGrid = sender as UltraWebGrid;
           //… Lots of good stuff
           reportId = SomeFunction( );
           stmGrid.ClientResponse.StatusMessage = string.Format( "reportId={0}", reportId );
    //Client-side stuff
    function PrintStatus( gridId, rowIndex )
        var grid = igtbl_getGridById( gridId );
        var row = grid.Rows.getRow( rowIndex );
        var params = "ReportName=PrintStatus";
        grid.invokeXmlHttpRequest( grid.eReqType.Custom, null, params );
        return false; //Don’t fire server-side event
    function DocumentGrid_XmlHTTPResponseHandler(gridName, rowId, gridResponse)
        //Add code to handle your event here.
        if ( gridResponse.StatusMessage.indexOf("reportId=") != -1 )
            var windowName = gridResponse.StatusMessage.replace("reportId=","");
            windowName = windowName.replace(/-/g,"");
            window.open( "../Reports/ShowReport.aspx?" + gridResponse.StatusMessage
                        , windowName
                        , "width=450, height=450, resizable=1, scrollbars=1" );
