Hello, after upgrading to the latest SR i get the following exception on the load data of a virtual collection binded to XamDataTree
at System.ThrowHelper.ThrowArgumentNullException(ExceptionArgument argument) at System.Collections.Generic.Dictionary`2.FindEntry(TKey key) at System.Collections.Generic.Dictionary`2.ContainsKey(TKey key) at Infragistics.Controls.Menus.NodesManager.DataManager_CollectionChanged(Object sender, NotifyCollectionChangedEventArgs e) at Infragistics.DataManagerBase.OnCollectionChanged(NotifyCollectionChangedEventArgs e) at Infragistics.DataManager`1.OnDataSourceCollectionChanged(NotifyCollectionChangedEventArgs e) at Infragistics.DataManagerBase.DataSource_CollectionChanged(Object sender, NotifyCollectionChangedEventArgs e) at Infragistics.Collections.VirtualCollection`1.OnCollectionChanged(NotifyCollectionChangedEventArgs args) at Infragistics.Collections.VirtualCollection`1.RaiseCollectionChanged(NotifyCollectionChangedEventArgs args) at Infragistics.Collections.VirtualCollection`1.NotifyItemChanged(T oldItem, Int32 collectionIndex) at Infragistics.Collections.VirtualCollection`1.LoadItems(Int32 index, IEnumerable`1 items) at BSNet.Andromeda.Base.ViewModels.ProductsViewModel.client_GetStockExchangeProductKindsCompleted(Object sender, GetStockExchangeProductKindsCompletedEventArgs e) at BSNet.Andromeda.StaticDataServiceReference.StaticDataServiceClient.OnGetStockExchangeProductKindsCompleted(Object state)
This appears to be an issue in the latest service release; the behavior is as expected in the prior service release (2097).
I have asked our engineering staff to examine this further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of 93320.
I will create a private case for you to track this issue.
Sincerely,ValerieDeveloper Support Engineer Infragisticswww.infragistics.com/support
