Working in version 9.2 in .net 2008. Using a ultraweblistBar that I programmatically populate the groups and also the items at runtime. If item list requires scrollbar and an item selected down in the list, the control postbacks to populate a grid but the scrollbar goes back to the top item within the group. Any code or setting to keep the scrollbar position after a postback?
I also set the Hover and SelectedItem settings to show a background color. When an item is selected the background color shows fine but when you hover the mouse over it again the background color disappears and does not go back to the selected color after moving off of the item that was selected. Is this a bug or is there a setting for this?
Hi jcom39201,
I am just following up to check whether you were able to resolve your issues. Please feel free to contact me if you need more help.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
Thank you for your reply. Feel free to contact me whenever you have the opportunity.
Petar,
I am out of town for 2 weeks. I will let you know if it works for me when I get back. Thanks for your reply!
Please let me know if you need more help with this matter.
Thanks for your reply and your patiance.
I have investigated this further and have created another a little simplified sample using CLR3.5 to illustrate my findings.
Here I am using hidden input fields which I get on the client by their clientIDs and this should work OK now. The Listbar is directly inside an WARP panel (and nothing else is inside that panel) and its RefreshComplete client-side event is used to set the scroller position of the listbar. The listbar's BeforeItemSelected event is used to set the value of the hidden field before postback.
I have placed the WARP with the listbar inside an UltraWebTab and that seems to work well (the ultraWebTab is inside an updatePanel which also seems to operate correctly). In my tests the ItemClicked server-side handler seems to be fired every time in Firefox, IE8 and IE9.
Please tell me if the sample works for you and whether a similar configuration in terms of nesting of elements is applicable in your case.
