90
Selected Row as SQL parameter
I have a WebGrid and and a FormView on a webpage. Both are bound to different SqlDataSource objects.  The WebGrid is set to allow Single row selection.  I would like to use the Data Key of the selected row in the WebGrid as a Select Parameter for the FromView's SqlDataSource, similar to the way you can do with a GridView:
 <SelectParameters>
<asp:ControlParameter ControlID="gvClientList" Name="ClientID" PropertyName="SelectedValue" Type="Int32" />
</SelectParameters>
Any idea how to make this work with the WebGrid?
  • 5
    I am facing the problem too.
    Current solution is to set a HiddenField.value =  the selected value.  and use the HiddenField.value as the parameter for the FormView's datasource.
        protected void UltraWebGrid1_SelectedRowsChange(object sender, SelectedRowsEventArgs e)
            foreach (UltraGridCell cell in e.SelectedRows[0].Cells)
                if (cell.Key == "the_key")
                   HiddenField1.Value = cell.Value.ToString();
