70
Slow with a large amount of data
Good morning.
I am using Infragistics Excel to treat a large amount of data that I bind to a XamGrid. The problem is that the loading of the grid takesover 15 seconds, while the data bind without using Infragistics Excel loads in less than a second. There are 35 000 rows and 50columns in my dataset.Here is how the data loading is done and the binding.
Do you know a way to speed up treatment?
Worksheet sheetOne =dataWorkbook.Worksheets.Add("Stock");
WorksheetRow worksheetRow = sheetOne.Rows[0];
for (int rowId = 0; rowId < e.Result.Count(); rowId++)
worksheetRow = sheetOne.Rows[rowId + 1];
worksheetRow.Cells[0].Value = e.Result[rowId].reference;
worksheetRow.Cells[1].Value = e.Result[rowId].abr_srayon;
worksheetRow.Cells[50].Value = e.Result[rowId].MB2;
<ig:XamGrid.Columns>
<ig:XamGrid x:Name="dataGrid" AutoGenerateColumns="False" Grid.Column="3" Margin="0,0,-852,0" >
<ig:TextColumn Key="Cells[0].Value"/>
<ig:TextColumn Key="Cells[1].Value"/>
<ig:TextColumn Key="Cells[2].Value"/>
<ig:TextColumn Key="Cells[50].Value"/>
  • 44743
    Suggested Answer
    If you are not already using version 11.1, I would strongly recommend upgrading to that version. There were many memory and performance enhancements made in that version. Then I would suggest using the WorksheetRow.SetCellValue method instead of getting the cell through the indexer and setting the Value property. SetCellValue is much faster and does not need to create a WorksheetCell instance, which makes a big difference when you are set the values of 1,750,000 cells. Also, I see that in your code, you are getting e.Result[rowId] 50 times (once for each cell). I would cache that in a local variable when you cache the row, so you don't need to index into e.Result 50 times at the same index.
