I want to display "N/A" in the pivot grid when the values are -1
my datasource is flatdatasource
is is possible?
Is there an alternative solution for displaying NA instead of cellcontrolattached?
because it is making the grid slower, and especially when scrolling
can i put it for loaded, or anything else?
Hi
Sorry for delay. There is a property which do this
pivotGrid.EditSettings.EditFormattedValue = true;
Setting it to true will solve the problem
Todor
ok thanks it worked,
but in this case when i click to edit the cell having the value NA , i get -1 instead of NA and this is not what i want :S
If yuo want NA to participate in sorting you should give them a double value. So change the follow line of code
cell.SetValue(-1.0, "NA", "NA");
put what value you need instead -1.0. Keep in mind that the value should be double
RegardsTodor
