990
Binding datachart with pivotgrid
hi,i am now using vol 11.2,
am binding the datachart with pivotgrid.
<ig:XamDataChart ToolTipStyle="{StaticResource ToolTipStyle}" Grid.Column="0"  Grid.Row="0"  x:Name="DataChart"  VerticalZoombarVisibility="Collapsed" HorizontalZoombarVisibility="Visible" HorizontalZoomable="True"   VerticalZoomable="False"   WindowResponse="Immediate"
                        DefaultInteraction="DragPan" Background="{x:Null}" CrosshairVisibility="Collapsed"
                        Cursor="Hand" GridMode="BehindSeries" PlotAreaBackground="#e6def5" Margin="3,2,10,0">
            <ig:XamDataChart.Axes>
                <ig:NumericYAxis x:Name="yAxis">
                    <ig:NumericYAxis.LabelSettings>
                        <ig:AxisLabelSettings Extent="25" Padding="0,5,0,0"/>
                    </ig:NumericYAxis.LabelSettings>
                </ig:NumericYAxis>
                <ig:OlapXAxis
                    x:Name="xAxis"
                    DataSource="{StaticResource FlatDataSource}"
                    OlapAxisSource="Columns"
                    AutoGenerateSeries="True"
                    YAxis="{Binding ElementName=yAxis}"/>
            </ig:XamDataChart.Axes>
            <ig:XamDataChart.Series>
            </ig:XamDataChart.Series>
        </ig:XamDataChart>
  <ig:XamPivotGrid Grid.Column="0"  Grid.Row="2"  RowHeaderStyle="{StaticResource RowHeaderCellStyle}"  AllowCompactLayout="True" DataSource="{StaticResource FlatDataSource}" x:Name="pivotGrid" AllowHeaderColumnsSorting="False" AllowHeaderRowsSorting="False" Padding="5,25,0,0">
            <ig:XamPivotGrid.EditSettings>
                <ig:EditSettings AllowCellEdit="True"/>
            </ig:XamPivotGrid.EditSettings>
when i remove the datachart, i can edit the cells in the grid, but when i put it again, i cant edit :S
so whats the problem? i want to edit the cells in the pivot grid and c the changes in the chart.
and is it possible to have stackedcolumnseries??
Parents Reply Children
No Data
