I updated my solution containing multiple silverlight navigation style projects and notice that while the utility properly updates the references in my projects, it fails to update the namespace references in the xaml files. Maybe because you didn't think to test with silverlight navigation apps which derive from Page instead of UserControl - the XAML looks like:
<navigation:Page x:Class="MolallaFM.Views.ONTs"
xmlns:ig="clr-namespace:Infragistics.Controls.Grids;assembly=InfragisticsSL4.Controls.Grids.XamGrid.v11.1"
xmlns:igm="clr-namespace:Infragistics.Controls.Menus;assembly=InfragisticsSL4.Controls.Menus.XamMenu.v11.1"
I basically have to open each XAML file and change the v11.1 to v11.2 which isn't a big deal, but I'm pretty sure the VU is suppose to do that also no???
Hello MolallaComm,
I have created case CAS-77543-TZL71B for you. You’ll be able to access this case from the My Support Activity page: <https://ko.infragistics.com/Membership/MySupport.aspx>.
I have also linked this case with the development issue 96030. I have sent you more details regarding this development issue through the support case.
I will update you with any new information after the review. Let me know if you have any questions.
Ok, got it. Thanks. I had Developer Support open a case about this, and they'll open a bug on this an associate it with the case so you can track it if you want.
Just add a project of type "Silverlight Navigation Application" to any project shoudl be enough to duplicate the problem. I believe that "Silverlight Business Application" would also work. If you can't duplicate that, drop me an e-mail and I will send you my XAML.
Sorry to hear about your issue with the utility. Would you be able to send us a simple project that uses this navigation:page? The utility should search all .xaml files an look for our references. I'll have DS open an case with you to get the project, or some more details.
