I'm attempting to bind to a list of objects where the object has a public property that is of type TimeSpan?. The reporting framework (11.2 latest greatest) doesn't seem to like this (see below).
Any thoughts on how to work around this?
Infragistics.Reports.Engine.EngineException: Couldn't get the data type associated with type 'TimeSpan'. There is no class with name System.TimeSpanDataType in the same assembly. ---> System.TypeLoadException: Couldn't get the data type associated with type 'TimeSpan'. There is no class with name System.TimeSpanDataType in the same assembly.
at Infragistics.Models.Data.DataTypeCatalog.GetDataTypeInstanceFieldName(Boolean allowProxys, Type dataObjectType, Boolean isStatic, Boolean throwExceptionIfNotFound, DataType& dataType, Type type, Type& dataTypeType)
at Infragistics.Models.Data.DataTypeCatalog.GetDataType(Type type, Boolean allowProxys, Boolean throwExceptionIfNotFound)
at Infragistics.Models.Data.DataTypeCatalog.GetDataType(Type type, Boolean allowProxys)
at Infragistics.Models.Data.DataTypeCatalog.GetDataType(Type type)
at Infragistics.Models.Data.Serialization.DataXmlWriter.Writer.GetPropertyValueType(DataProperty property, Object value)
at Infragistics.Models.Data.Serialization.DataXmlWriter.Writer.CanBeSerializedInAttribute(DataProperty property, Object value, String bindingExpression)
at Infragistics.Models.Data.Serialization.DataXmlWriter.Writer.WriteAttributes(DataPropertyValueCollection values, DataType ownerDataType, DataType objDataType, DataProperty contentProperty, Int32 offset)
at Infragistics.Models.Data.Serialization.DataXmlWriter.Writer.WritePropertyValues(DataObject obj, DataType ownerDataType, Int32 offset)
at Infragistics.Models.Data.Serialization.DataXmlWriter.Writer.WriteObject(DataObject obj, DataType ownerDataType, Boolean writeTags)
at Infragistics.Models.Data.Serialization.DataXmlWriter.Writer.WriteItem(Object item, DataType ownerDataType, DataProperty property)
at Infragistics.Models.Data.Serialization.DataXmlWriter.Writer.WriteCollection(IDataCollection collection, DataType ownerDataType, DataProperty property)
at Infragistics.Models.Data.Serialization.DataXmlWriter.Writer.WritePropertyValue(DataProperty property, Object value, DataType objDataType, Boolean isContent, String contentStringValue, Boolean contentPreserveSpaces)
at Infragistics.Models.Data.Serialization.DataXmlWriter.Writer.WritePropertyInElement(DataProperty property, Object value, DataType ownerDataType, DataType objDataType, String bindingExpression)
at Infragistics.Models.Data.Serialization.DataXmlWriter.Writer.WriteChildElements(DataPropertyValueCollection values, DataType ownerDataType, DataType objDataType, DataProperty contentProperty)
at Infragistics.Models.Data.Serialization.DataXmlWriter.SaveToString(DataObject obj, DataXmlWriterSettings settings)
at Infragistics.Reports.Engine.FragmentSerializer.SaveToString(DataObject fragment, DataXmlWriterSettings settings)
at Infragistics.Reports.Engine.FragmentSerializer.Serialize(Stream stream, Fragment fragment)
at Infragistics.Reports.Engine.MemoryReportStorage.Serialize[T](ISerializer`1 serializer, T value)
at Infragistics.Reports.Engine.MemoryReportStorage.Save[T](String moduleName, String key, Int32 index, T value, ISerializer`1 serializer)
--- End of inner exception stack trace ---
HI,
I am just following up on this forum thread.
Please let me know if you need further assistance.
Sincerely, Matt Developer Support Engineer
This issue should be resolved by the latest service release.
This is a bug (internal issue number 96112). The serializer is having issues with the TimeSpans. As a workaround you can force the time span to be converted to string. For example, if the expression that returns a time span is =Fields.Period you should use =Fields.Period.ToString() instead.
Hope it helps.
Leo
