The Silverlight 5 Release Candidate is out and I would like to start testing it in my application in anticipation of the SL5 release. Before I do that and because a crucial part of my application relies on the DataChart I thought I would ask here to see if anyone has already done some testing.
Does anyone know if there are any issues related to running version 11.2 of the xamDataChart on Silverlight 5?
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
If this is what you were looking for please verify the answer so it helps other users as well.
I experienced an issue with the RC where I couldn't use a uri based xmlns definition to reference the Infragistics namespaces and had to use clr-namespace + assembly in the namespace mapping instead. But this is the only issue I've personally run into thusfar.
