We've located a problem that happens in XamComboEditor v11.2 (11.2.20112.1010) when a line exceeds width of XCE, but drop-down is already rendered. Below is a minimal setup for reproduction.
IE. click drop-down to make list stay open. When one _drags slowly_ the "car" down until "mmmmm" entries appear, application crashes in MeasureOverride. When one directly clicks on non-car area of scrollbar and list jumps directly to a place, no crash happens.
If one relocates the Id=20 entry to the top, so that it's immediately rendered into dropdown, it'll not crash here, but will when one scrolls to bottom (horizontal scrollbar disappears while scrolling).
Xaml:
<ig:XamComboEditor Name="XamCE" AutoComplete="True" CustomValueEnteredAction="Ignore" DisplayMemberPath="Code" Width="245" Height="22" />
Data:
public class A { public int Id { get; set; } public string Code { get; set; } } XamCE.ItemsSource = new A[] { new A { Id = 1, Code="aaaaaaaaaa aaaaaa aaaa"}, new A { Id = 2, Code="bbb bbb bbbbbbbbb"}, new A { Id = 3, Code="ccccc ccccc"}, new A { Id = 4, Code="dddddd ddd dddddd ddddddd dd"}, new A { Id = 5, Code="eee eeeeeeeee"}, new A { Id = 6, Code="f ffffffffff ff ff"}, new A { Id = 7, Code="gg gggggggggg ggg"}, new A { Id = 9, Code="h hhhh hhhhh"}, new A { Id = 11, Code="iiiiii iiiiiiiiii iiiiiiii"}, new A { Id = 12, Code="jjjjjj jjjjjj jjjjjjjjjjjjjjj jj"}, new A { Id = 16, Code="kkkkkkkkk kkkkkkkkkk"}, new A { Id = 17, Code="lllllllll llllllllllll"}, new A { Id = 20, Code="mmmmmmmmm mmmmmmmmmmmmm mmmmmmmmmm mmmm mm mm"}, new A { Id = 31, Code="nnnnnnnnn nnnn nnnn "}, new A { Id = 32, Code="ooooooooo oo oooo"}, new A { Id = 33, Code="pp pppp pp pppp"}, new A { Id = 35, Code="qqqqqqqqq qq qqqq"}, new A { Id = 38, Code="rrrrrrrrr rrrr "}, new A { Id = 40, Code="sssssssss ssssss"}, new A { Id = 50, Code="ttttttttt tttttttttttt tttt"}, new A { Id = 52, Code="uuuuuuuuu uuuu"}, new A { Id = 76, Code="xxxxxxxxx xxxxxxxxxx xxxx"}, new A { Id = 91, Code="yyyyyyyyy yyyyy"}, new A { Id = 98, Code="zzzzzzzzz zzzzzzzzzz"}, new A { Id = 101, Code="11111111 1111111111 1111111111111 1111111"}, };
That was fast!
Thank you very much.
Best Regards,Julien Benoit
Hi psavo,
the issue is fixed and the fix is included in the latest SR for 11.2.
Hello Duane,
What the progress on this issue? I just got the same issue in production.
Is there a workaround? Is it fixed in the latest service release?
Hello psavo,
CAS-78970-S0FJ22 has been linked to development ID 96957. You can also find this case at the support activity page: https://ko.infragistics.com/Membership/MySupport.aspx.
Feel free to ask any questions or if you require any further assistance with XamComboEditor.
I've managed to reproduce the issue you are describing. A development issue has been submitted with ID 96957. I've also created a support case on your behalf so you could get notified when there is a release containing the fix. The case id is CAS-78970-S0FJ22. I suppose the fix will get into the upcoming service release which is expected to be out some time next week.
Thanks a lot for your feed back.
