670
Grid Cell Dynamically disabled or value changed based on change in another field in that row
I saw this post (https://ko.infragistics.com/community/forums/f/retired-products-and-controls/53503/enabling-individual-checkbox-cell-s-in-webgrid/276918#276918) about checkboxes, however, the example that is mentioned to be attached, does not appear to be attached any longer.  Can we get another sample of this?
Also, is there a way that you can access any other cells other than the adjacent cell?  We need to be able to disable/mark as readonly other cells in that row beyond the adjacent cell?  We will not know where the other columns will be as the user can move things around, so we would need to find them via the column key and be able to edit that cell or make it readonly or enabled based on the current columns values.
We are using the WebDataGrid in 2011v1.2116.
I looked in the WebDataGrid1_RowUpdated and WebDataGrid1_InitializeRow events but the objects you could get did not seem to have a way to get to cell's enabled/disabled property.
Parents Reply Children
No Data
