When I have 2 Y axis, the gridlines for both axis doesn't overlap, so it is showing 2 grids. Please see the attached sample and tell me if I do something wrong.
HI,
I am just following up on this thread. Please let me know if you need further assistance.
Sincerely, Matt Developer Support Engineer
If you have multiple y axes with disimilar ranges then their gridline will not align, and this is by design. Each y axis is using the optimal breakdown of its range into subranges. Here are some of the various options you can employ if the display is not as you desire:
It would be possible to add the 3rd option as a native feature of the chart, but it is not a native option currently. If that is the most appealing scenario you may want to make a feature request for this behavior. In the meantime, you will need to control the minimumValue and MaximumValue manually to achieve the described effect.
Hope this helps!
-Graham
