I'm using a UltraWebTree inside a UltraWebListBar and want them to score 100% what concerns to accessibility. All images have their respective 'alts', but when i see the source generated by the browser, i notice that the UltraWebTree as an "img tag" inserted by their own, that doesn't have the 'alt' attribute. Not having the 'alt' attribute, this fails the accessibility test:
I started from your treeview ASPX setup and changed only the Visible property to True so that the treeview is displayed - then I ran the treeview output through Section 508 validator and the check passed successfully: Here is the validator I used and the HTML I got from your ASPX declaration (I am using version 2008.3):
http://www.section508.info/
Maybe the best way is to isolate a small subset of your project reproducing the issue and sent it directly to our official Developer Support department -
http://ko.infragistics.com/Support/#Overview
Thanks for looking into it. This was from a page that was converted from an old version of infragistics/.net so that might be a contributing factor but I don't know what other settings would be needed to get 508 compliant output. Hope this helps!
<ignav:ultrawebtree id="tvwRecruitment" tabIndex="11" Width="163px" runat="server" AutoPostBack="False"
Font-Names="Arial" Font-Size="10pt" Section508Compliant="True" BrowserTarget="DownLevel" SingleBranchExpand="True"
WebTreeTarget="HierarchicalTree" Indentation="10" FileFlags="StylesOnly" Visible="False">
<autopostbackflags nodechanged="True" />
<Nodes>
<ignav:Node TargetUrl="" TagString="/Staffing/Vacancy/Vacancy.aspx" Text="Position Information"></ignav:Node>
<ignav:Node TagString="/Staffing/Vacancy/VacancyAssessment.aspx" Text="Assessment Information"></ignav:Node>
<ignav:Node TargetUrl="" TagString="/Staffing/Vacancy/Documentation.aspx" Text="Supporting Documents"></ignav:Node>
<ignav:Node TargetUrl="" TagString="/Staffing/Vacancy/VacancyCategory.aspx" Text="Categories"></ignav:Node>
</Nodes>
<SelectedNodeStyle ForeColor="White" BackColor="Navy"></SelectedNodeStyle>
<NodePaddings Bottom="1px" Top="1px"></NodePaddings>
<Padding Top="1px"></Padding>
<Levels>
<ignav:Level Index="0"></ignav:Level>
</Levels>
<ClientSideEvents NodeClick="ValidatedNodeClick" BeforeNodeSelectionChange="BeforeNodeClick"></ClientSideEvents>
</ignav:ultrawebtree>
Hello Andrew,
I am trying to reproduce the issue (alt tags missing for 2008.3 UltraWebTree when WebTreeTarget = Hierarchical and Section508Compliant = True), but unfortunately without much success. As far as I can tell, all images have their corresponding alt property set (either to "(Expanded)" / "Collapsed") for expand / collapse image to alt = "" for node images.
Am I missing something? Can you please paste your ASPX tree declaration so I can reproduce that?
This apparently is still an issue in 2008 volume 3 when the tree control has WebTreeTarget=Heirarchical
-Andrew Douglas
Thanks!
