190
Conditional checkbox enabled in xamgrid
I would like to have a checkbox in the xamgrid be enabled conditionally on data that is in the same row as the data behind the grid, so for example
data behind is
tool name / is checked out / by whom
hammer false numm
saw false null
rake true me
screw driver true notme
so the grid would have three columns and the only time the check box is enabled is when it is not checked or when it is checked and by whom equals me.
When I attempted using a template and used the on load event to set the checkbox, when I scrolled down I saw other rows that eneded up being checked.  Do you have advice?
  • 6912
    Suggested Answer
    hi,
    You can try to use TemplateColumn. The ItemTemplate will be a checkbox and you can control the Visibility of the checkbox using a custom IValueConverter. It will look something like that:
    <DataTemplate>
       <CheckBox IsChecked="{Binding IsCheckedOut}" Visibility="{Binding IsCheckedOut, Converter={StaticResource MyCustomBoolToVisibilityConverter}}" />
    HTH
