1015
Version utility
Hello!
Once again the version utility. I have no clue why this is happening, but I get an error that my asp-project could not be updated. The log reads like this:
10:38:52: Running User Interface Version 11.2.20112.1000
10:38:52: Gathering volume and assembly information.
10:41:10: D:\Ettfs1\OpenLS6000-V7\Current\Sources\Dms.EM.Vi\Source\EM.Vi\EM.Vi\DataConnector.cs appears to be read-only or not accessible for some reason.
10:42:14: Analyzing EM.VI.csproj...
10:42:14: The project has references that need to be updated.
10:43:21: Analyzing EM.VI.csproj...
10:43:21: The project has references that need to be updated.
10:44:26: Gathering volume and assembly information.
10:44:27: Analyzing EM.VI.csproj...
10:44:27: The project has references that need to be updated.
10:45:26: Replacement for Infragistics35.WebUI.UltraWebChart.v10.3 is Infragistics35.WebUI.UltraWebChart.v11.2.
10:45:26: Replacement for Infragistics35.WebUI.Shared.v10.3 is Infragistics35.WebUI.Shared.v11.2.
10:45:26: No matching assembly located in available assemblies Infragistics35.WebUI.UltraWebGrid.v10.3
10:45:26:    bei Infragistics.VersionUtilitySupport.Core.ProductAssemblies.AssemblyXmlFile.GetNewAssemblyNameBecauseOfNameChangedBetweenVolumes(String assemblyName, Int32 indexOfVolumePortionOfAssemblyName, XmlNamespaceManager xmlNamespaceManager, Boolean ignoreErrors)
   bei Infragistics.VersionUtilitySupport.Core.ProductAssemblies.AssemblyXmlFile.LocateNewAssembliesNodeforCurrentAssembly(String assemblyName)
   bei Infragistics.VersionUtilitySupport.Core.File.Types.WebConfigFile.FixAssembly(XmlNode n)
   bei Infragistics.VersionUtilitySupport.Core.File.Types.WebConfigFile.UpgradeInfragisticsAssemblyTags()
   bei Infragistics.VersionUtilitySupport.Core.File.Types.WebConfigFile.Upgrade(String rootDirectory)
   bei Infragistics.VersionUtilitySupport.Core.File.Types.FileBasewithWebConfig.Upgrade(String rootDirectory)
   bei Infragistics.VersionUtilitySupport.Core.File.Types.ProjectFile.Upgrade(String rootDirectory)
Had anybody a similar problem or can anybode give me a hint what's (/ what I'm doing) wrong?
Uli
