840
how to clear the webdata tree nodes on client side
I have implemented the webtree view funcationality on the client side. I have done following things
Adding of parents and its childs and its working fine. but the problem is while adding new nodes, previous nodes are not clearing . I did not find clear nodes method in Client Side Api.
Can you let me know how to clear the nodes on client . i want clear the all the nodes from the client side.
Thanks in advance
  • 49378
    Hi anilkoomar_1202,
    Removing individual nodes client-side can be achieved using the remove() function. For instance the first child of the first root can be done using:
    ig_controls.WebDataTree1.getNode(0).get_childNode(0).remove()
    You can "clear" all items from the tree by removind all root nodes. This can be achieved using something similar to:
            function removeAll() {
                while (ig_controls.WebDataTree1.getNodes().get_length() > 0) {
                    ig_controls.WebDataTree1.getNodes().getNode(0).remove();
    Please let me know if this helps.
    • 840
      posted in reply to [Infragistics] Petar Ivanov
      Thanks for your  reply,
      I have got the solution
        function ClearNodes() {
                  currentTree = $find('<%= WebDataTree1.ClientID %>');
                             var tree = currentTree;
                  var nodes = tree.getNodes();
       var len = nodes.get_length();
                  // Loop Thru Root Items
                  for (var i = len - 1; i > 0; i--) {
                      var node = nodes.getNode(i);
                      tree.remove(node, false); //dispose()
      • 10
        Hi
        I have one wired requirement please suggest me how can be that done with infragestics
        let us take book and chapter example
        I need to provide the filter to my tree view
        suppose if i am searching with some chapter name xyz ,control should go to that node expand it and mark it with green
        Thanks&Regards,
        Srikanth
        • 49378
          posted in reply to anil kumar
          Hi anilkoomar_1202,
          Please feel free to contact me if you have any further questions.
      x An error occurred. Please try again or contact your administrator.
