I wish to know how can I update the GroupByRow Header after datas updating.
In fact, I applying a group on my XamGrid as this :
When I wish to modify a data with the form on right, The row was updated correctly but not the GroupByRow Header :
Best Regards,
Yoann.
Hello Mani_Infineon,
For this related forum post is currently linked to the case CAS-84734-9K8FJ6. You can find this case at the support activity page: https://ko.infragistics.com/Membership/MySupport.aspx.
Let me know if you have any questions with this matter. Thank you.
I have the same problem. Can you please post a solution or workaround. It's very urgend.
Hello Cosoluce_Stones,
Thanks for the attachment the thread.
Case CAS-81648-KZTL4M has been assigned for this and I will get back to you on the case for any questions.
You can find the case in the support activity page here: https://ko.infragistics.com/Membership/MySupport.aspx
Can someone help me ?
Regards.
Hi Duane,
I already install the lastest service release of NetAdvantage 2011 Vol2.
I attach a sample in this post . You just need to launch the solution, select a row and to clic to the 'InvalidateData' button at the bottom.
Best regards,
