390
How to remove dot?
I use a XamNumericEditor, set Mask to "{double:-12.5}". I want to input both integers and doubles. When I input 12 in the editor, and make it lose focus, it appears "12." in the editor, number "12" followed by a dot. How can I hide the dot for integer after it loses focus?
Regards
  • 2070
    Hi jifangeva,
    If you are using 11.2 or newer version there's a new XamNumericInput control which has TrimFractionalZeros property which you can set to eliminate non-significant zeros in the fractional part as well as eliminate the '.' when you leave the editor.
    Hope this helps,
    Sandip
