2235
client side event on webcombo. cancel or not to cancel.
On a webcombo. I have a clientSideEvents AfterSelectChange.
If runs a client side script as follow.
function validate() {
			if (document.getElementById("<%=wcPerCitizenship.ClientID %>"))
				var retval = confirm("Are you sure you want to change this?");
				if (retval)
					return true;
				else
					return false;
So what I am trying to do is, if the retval is true than allow the change, if it is false than do not allow the change.
When I select either it seems to allow the change anyway.
Any help on this? DO I have the correct event to do this with?
