I have a grid that has a description and 4 value columns. There are only 6 rows of records for this grid. In the first 4 rows, all 4 values are used with a label name. In the last two rows, only the 1rst value is used with a different label name. My question is If you click on one of the first 4 rows, I want the RowEditTemplate to display the labels and textboxes for editing all 4 columns, if one of the last two rows are clicked, I want to display only the labels & textboxes for editing the first column. Can I have more than one RowEditTemplate and, if so, how do I determine which one to use for the row clicked. If not, is there a way to do this, like if row 1-4 is clicked show such-and-such labels and textboxes, and if row 5-6 is clicked show only those labels and textboxes? This is a program requirement that I was able to do with a different third-party grid control in the past, but don't know how to do this with the UltraWebGrid. Thanks much for anyone who can help with this.
Hi dbishop9,
In this scenario I would suggest hiding/showing the relevant elements inside your row editing template in the BeforeRowTemplateOpen client-side handler. For instance here is some sample code which would hide the first textbox in a (default) edit template for all even indexed rows:
function UltraWebGrid1_BeforeRowTemplateOpenHandler(gridName, rowId, templateId) { if (igtbl_getRowById(rowId).getIndex() % 2 == 0) { igtbl_getElementById(templateId).children[0].children[0].style.display = "none"; } else { igtbl_getElementById(templateId).children[0].children[0].style.display = ""; } }
This assumes that the created by default row edit template is used:
<RowEditTemplate > <p align="right"> ProductID <input id="igtbl_TextBox_0_0" columnkey="ProductID" style="width: 150px;" type="text"> <br> ProductName <input id="igtbl_TextBox_0_1" columnkey="ProductName" style="width: 150px;" type="text"> <br> SupplierID <input id="igtbl_TextBox_0_2" columnkey="SupplierID" style="width: 150px;" type="text"> <br> CategoryID <input id="igtbl_TextBox_0_3" columnkey="CategoryID" style="width: 150px;" type="text"> <br> </br> </input> </br> </input> </br> </input> </br> </input> </p> <br> <p align="center"> <input id="igtbl_reOkBtn" onclick="igtbl_gRowEditButtonClick(event);" style="width: 50px;" type="button" value="OK"> <input id="igtbl_reCancelBtn" onclick="igtbl_gRowEditButtonClick(event);" style="width: 50px;" type="button" value="Cancel"> </input> </input> </p> </br> </RowEditTemplate>
Please let me know if this helps.
I'm not having much luck since I am not using basic input controls. This is my RowEditTemplate. I am using a table with labels and textboxes. If I select a specific row in the grid (4 or 5), I need to hide the controls(or rows) for Value2, Value3, & Value4, but leave the Value1 controls(or row) visible, and change the Value1 description label text.
<RowEditTemplate > <div id="divControls" style="background-color: #E5ECFD;"> <p align="left" style="padding: 2px 2px 2px 2px; border-color: Lightgray; border-width: 1px; border-style: solid;"> <asp:Table ID="tblControls" runat="server"> <asp:TableRow> <asp:TableCell Width="85px"> <asp:Label ID="lblID" runat="server" Visible="false">ID</asp:Label> </asp:TableCell> <asp:TableCell> <asp:TextBox ID="txtID" runat="server" Enabled="false" ToolTip="ID" columnkey="ID" BorderStyle="none" BackColor="#E5ECFD" ForeColor="#E5ECFD" Font-Size="0"></asp:TextBox> </asp:TableCell> </asp:TableRow> <asp:TableRow> <asp:TableCell Width="155px"> <asp:Label ID="lblValue1" runat="server" >Not Eligible For Renewal</asp:Label> </asp:TableCell> <asp:TableCell> <asp:TextBox ID="txtValue1" runat="server" ToolTip="Not Eligible For Renewal" Width="85px" columnkey="VALUE1"></asp:TextBox> </asp:TableCell> </asp:TableRow> <asp:TableRow> <asp:TableCell Width="155px"> <asp:Label ID="lblValue2" runat="server">Voluntary Termination</asp:Label> </asp:TableCell> <asp:TableCell> <asp:TextBox ID="txtValue2" runat="server" ToolTip="Voluntary Termination" Width="85px" columnkey="VALUE2"></asp:TextBox> </asp:TableCell> </asp:TableRow> <asp:TableRow> <asp:TableCell Width="155px"> <asp:Label ID="lblValue3" runat="server">Involuntary Termination</asp:Label> </asp:TableCell> <asp:TableCell> <asp:TextBox ID="txtValue3" runat="server" ToolTip="Involuntary Termination" Width="85px" columnkey="VALUE3"></asp:TextBox> </asp:TableCell> </asp:TableRow> <asp:TableRow> <asp:TableCell Width="155px"> <asp:Label ID="lblValue4" runat="server">Pct Renewed On Time</asp:Label> </asp:TableCell> <asp:TableCell> <asp:TextBox ID="txtValue4" runat="server" ToolTip="Pct Renewed On Time" Width="85px" columnkey="VALUE4"></asp:TextBox> </asp:TableCell> </asp:TableRow> </asp:Table> </p> <p align="center" style="background-color: #D5DDEA; vertical-align: middle; padding: 2px 2px 0px 2px; border-color: Gray; border-width: 1px; border-style: solid;"> <asp:ImageButton ID="ibtnOK" runat="server" ImageUrl="~/Images/oknew.png" OnClick="ibtnOK_Click" /> <asp:ImageButton ID="ibtnCancel" runat="server" ImageUrl="~/Images/cancelnew.png" /> </p> </div></RowEditTemplate>
Thanks, Petar. Apparently, the javascript isn't firing. I have set IE8 to allow debugging javascript, change the config mgr to Debug in VS2008. I put a debugger; call in the function, as well as alert('something here');, but neither will fire. I'm not used todebugging javascript in the IDE, so I may not have something still set right to debug it. But even so, the alert() call should fire, so I don't think my javascript is firing. Below is the script. I have to get this working and I'm not sure if VS2008 is even allowing me to debug the javascript. Is there a step to turning on javascript debugging Ive missed?
<script type="text/javascript">function igStop031_BeforeRowTemplateOpenHandler(gridName, rowId, templateId) { if (igtbl_getRowById(rowId).getIndex() < 4){igtbl_getElementById(templateId).children["divStop031Controls_A"].style.setAttribute('display','');igtbl_getElementById(templateId).children["divStop031Controls_B"].style.setAttribute('display','none');}else if (igtbl_getRowById(rowId).getIndex() == 4) {igtbl_getElementById(templateId).children["divStop031Controls_A"].style.setAttribute('display','none');igtbl_getElementById(templateId).children["divStop031Controls_B"].style.setAttribute('display','');} else if (igtbl_getRowById(rowId).getIndex() == 5){ igtbl_getElementById(templateId).children["divStop031Controls_A"].style.setAttribute('display','none');igtbl_getElementById(templateId).children["divStop031Controls_B"].style.setAttribute('display','');} } </script>
This is a followup. I am able to debug javascript, however, NONE of the infragistics javascript is firing. If I create my own function for an input button like
alert(
"hi this is a test");
It fires and debugs. But my Infragistics scripts don't. such as
function igMyGrid_BeforeRowTemplateOpenHandler(gridName, rowId, templateId) {
"hi_BeforeRowTemplateOpenHandler");
var row = igtbl_getRowById(rowId);
var currentVal = row.getCell(2).getValue();
dateChooser.value = currentVal;
dateChooser.inputBox.value = currentVal;
var dateChooser = null;
function igMyGridDueDate_InitializeDateChooser(oDateChooser) {
//Add code to handle your event here.
"hi_InitializeDateChooser");
dateChooser = oDateChooser;
These do not fire! Is there some setting in the grid or otherwise to enable them to work? I don't see any mis-spellings in the naming. But I can't figure out what would keep them from firing.
Hi Petar, another followup. I didn't know I had to specifically register the client-side events. I've never had to do that in other controls. Now that I've done that, the events are firing just fine. I still can't get the display format to be correct. The edit format is fine, and once you select a date, the format is fine, but that initial value is not displayed correctly. I have the control set to "d" and I've tried setting it in the server-side initalization of the row and the control itself, with no luck. How can I set it client-side?
Last followup. I have resolved the issue on my own. While this may not be the "best" way to do it, it is the only one so far that works for me. What I did was, in the BeforeRowTemplateOpenHandler, just before I assign the cell's date value to the WebDateChooser, I manually format the UTC date by using a bit of free javascript from the following link rather than spending time building my own formatting function.(I don't know if it's okay to include an outside link or not).
http://blog.stevenlevithan.com/archives/date-time-format
So my code is now as follows:
function igMyGrid_BeforeRowTemplateOpenHandler(gridName, rowId, templateId) { var row = igtbl_getRowById(rowId); var currentValDueDate = row.getCell(1).getValue(); var currentValueCompletedDate = row.getCell(6).getValue(); currentValDueDate = dateFormat(currentValDueDate, "mm/dd/yyyy"); currentValueCompletedDate = dateFormat(currentValueCompletedDate, "mm/dd/yyyy"); dateChooserDueDate.value = currentValDueDate; dateChooserDueDate.inputBox.value = currentValDueDate; dateChooserCompletedDate.value = currentValueCompletedDate; dateChooserCompletedDate.inputBox.value = currentValueCompletedDate;}
function igMyGridDueDate_InitializeDateChooser(oDateChooser) { dateChooserDueDate = oDateChooser;}function igMyGridCompletedDate_InitializeDateChooser(oDateChooser) { dateChooserCompletedDate = oDateChooser;
This now makes the WebDateChooser display the initial date value as 02/01/2012, as it is supposed to. Again, I'm still not sure what I have set/notset that was causing the previous methods to fail, but this overrides that and gives me the expected result I need, my project can continue now.
Thank you for your replies and for sharing your solution. Please feel free to contact me if you have any further questions.
