I've found very hard to enter edit mode in a cell for a column which accepts null values. When you are adding a row through editing in the grid, cells refuse to enter edit mode. They act like they were labels or read only controls. If you try very hard, finally you'll be able to edit the cell, but it will be a little tricky to get there.
Am I missing something or is this an inconsistent behavior in your grid?
Many thanks and bye ...
Hi Anatoli,
Many thanks for your reply.
I can understand what you say, however, in some cases users want to edit data *directly* in the grid. Do you agree with me?
I find editing in IG grid possible and correct, *only* when some data accepts null at table definition I can see this behaviour, I mean editing is very hard *directly* in the grid.
Thanks for your answer again and bye ...
Alternative way to edit data on some row is to use the "Edit" button when this row is selected.
Best regards,
Anatoli Iliev
