1235
Weird error message when binding ItemsSource to IEnumerable<T> and solution
I ran into this  issue and I wanted to signal it if someone else stumble on it as well.
XAML
XAML
 <ig:XamGrid ItemsSource="{Binding Path=GridTreatmentDetails}"
                            AutoGenerateColumns="False" >
  <ig:XamGrid.Columns>
      <ig:DateColumn Key="DetailDateAsDateTime" HeaderText="DATA"/>
      <ig:TextColumn Key="Description" HeaderText="DESCRIZIONE"/>
       <ig:TextColumn Key="LastAndFirstName" HeaderText="PAZIENTE"/>
       <ig:TextColumn Key="TranslatedState" HeaderText="STATO"/>
   </ig:XamGrid.Columns>
ViewModel
 GridTreatmentDetails = workHorseQuotes
.SelectMany(td => td.MergedTreatmentDetails);
GridTreatmentDetails is an IEnumerable<T> where T
is my custom class.
I receive a runtime error that says:
 The following key(s) do not correspond with the DataSource: "DetailDateAsDateTime".
If you'd like to add additional columns, please use the UnboundColumn type.
It looks like my class does not have a DateTime property named  DetailDateAsDateTime, but in fact
I do have this property.
To solve the issue you need to modify:
 GridTreatmentDetails = workHorseQuotes.SelectMany(td => td.MergedTreatmentDetails);
as following:
as following:
.SelectMany(td => td.MergedTreatmentDetails).ToList();
Now, while I can understand the reason (now), it would help immensly to receive a different error message.
Best regards
Roberto
