I'm using the infra grid with GroupBy enabled, when I GroupBy a date field, it shows the time (2/1/2012 12:00:00 AM), even though Time is not enabled in the grid.
I am also lookin for a solution for this issue i.e. when Group By enabled for Date column it is displaying date and time also even it is not enabled. could please provide me some inputs if you already resolved this issue as you informed above you logged a ticket with development team.
please provide the solution ASAP.
Thanks in advance.
Chandrasekhar.
I have logged this with development under ID: 101442 and I have also created a support ticket on your behalf: CAS-83558-268BTY and have linked the development issue to it, so that you can get automatically updated, when a Service Release containing the fix is available for download. You can get the new version from our website’s “My IG”, “My Keys & Downloads” tags: https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
You can also monitor the support ticket’s progress through the “My Support Activity” tag: https://ko.infragistics.com/Membership/MySupport.aspx
Hello ,
I have been looking into your issue and I have been able to reproduce the behavior you described. I am going to contact our development team to check if this can be fixed.
I will update you shortly on my progress.
