I am not able to load an iframe with html generated from ASPX page containing Infragistics webcombo control. it errors out at this line
oWebCombo1xxGrid = igtbl_initGrid("WebCombo1xxGrid" ..................
but when I set the source of iframe to this page, then it works fine. but I can't set the source like this, because the html that is generated is dynamic (generated through xml transformed into html using xslt).
I am using the following code to write html into iframe
var frame = document.getElementById("iFrame"); var doc = frame.contentWindow.document; doc.open(); doc.write(xmlHttp.responseText); doc.close();
I think it shouldn't be any different in setting a source OR writing html dynamically into iframe like this. I tried putting a normal asp.net dropdownlist control, then it doesn't generate any error when I load iframe using the code above. it only causes problem with webcombo control.
Please help.
