1750
divide cell values by 100 ?
is there a way to show cell data divided by a value ?
p.e  /100
Parents
No Data
Reply
  • 17559
    Verified Answer
    Hello ipappous,
    I have been looking into your requirements and  in order to fulfill them I can suggest you add a style for the PivotCellControl and manually convert the shown text in the cells. You can achieve this for example by adding the following style for the PivotCellControl:
                <Style TargetType="ig:PivotCellControl">
                    <Setter Property="Template">
                        <Setter.Value>
                            <ControlTemplate TargetType="ig:PivotCellControl">
                                <Grid>
                                    <Border x:Name="Root" BorderBrush="{TemplateBinding BorderBrush}" BorderThickness="{TemplateBinding BorderThickness}"
                            Background="{TemplateBinding Background}" />
                                    <Grid>
                                        <Grid.ColumnDefinitions>
                                            <ColumnDefinition Width="*" />
                                        </Grid.ColumnDefinitions>
                                        <TextBlock Name="cellPresenter" Text="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Cell, Converter={StaticResource con}}"
                                    Grid.Column="1" VerticalAlignment="Center" HorizontalAlignment="Left" Margin="5" />
                                    </Grid>
                                </Grid>
                            </ControlTemplate>
                        </Setter.Value>
                    </Setter>
                </Style>
    And convert the value as follows:
       public class FormatValueConverter : IValueConverter
            #region IValueConverter Members
            public object Convert(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
                if (value != null)
                    PivotCell pCell = (value as PivotCell);
                    ICell cell = pCell.Data as ICell;
                    if (cell != null&& cell.Value is double)
                        return (double)cell.Value / 100;
                return "";
            public object ConvertBack(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
                return "";
            #endregion
    If you need any further assistance on this matter, please do not hesitate to ask.
Children
No Data
