When Change the itemsource eg.. add new item to the collection .. the drag not work .... and I have to reload the application
Hello ankm,
It has been a while since you have made this post, if you need any support on this matter I will be glad to help. I have created a small sample where I try to reproduce the described by you scenario, still on my side everything works as expected. Would you please modify my sample in order to reproduce your issue so I can continue investigating it.
Thanks in advance.
