Hey tehre infragistics team,
I am currently testing your new Reporting Solution...which is of to a great start...but still lacks in a lot of fields. Well, for now I want to do the following:
I use Visual Studio 2010 and created two reporting files (*.igr) within my project.
I formatted those reports and create a simple dialog with the UltraWinReportViewer Control.
I can now bind a report to the Report Viewer.... but what i basicly want is to bind more then one report to the viewer (ut only one at a time)
What I wish for is to call my dialog something like this:
Dim _dlg as new dlgReportViewer("order.igr")
Dim _param As New Infragistics.Win.UltraWinReportViewer.Parameter()
_param.ParameterName = "Order_ID"
_param.ParameterValue = m_Order.ID
_dlg.ReportViewer..Parameters.Add(_param)
_dlg.ShowDialog()
and ....voila! I can bind a report by using my constuctor.... unfortunately it seems I need to create one Reporting Dialog for each report file....which would be seriously stupid....and knowing the intelligent people at Infragistics I just know there must be a better way to do this.
Let me ask you one more thing: Where do you wish to go with your Reporting Solution? It has a lot of great features allready but is missing pretty basic things too (Grid-Lines for better alignment, resizing the grid-cells for better aligning, vertical lines, rtf-support, more charts, ...)
I wish you best of luck with this product and hope for a quick reply.
ChaosC0der
you would: rptView.Parameters.Clear();
Here's a solution that could help you. It will be efficient but quite not perfect.
You could try creating multiple report headers. But you should adjust your headers size so that they fit in one page.
There's another solution I found here. I hope it helps.
I see you already found a way of doing this, for future reference here is a snippet on how to instantiate Client & Server rendering settings, when setting this property the viewer.will automatically try to render and refresh its view.
// Server RenderSettings
xamReportViewer1.RenderSettings = new ServerRenderSettings{
DefinitionUri = new Uri("MyAssembly;component/MyReport.igr", UriKind.RelativeOrAbsolute),
ServiceEndpointUri = new Uri ("/ReportService.svc", UriKind.RelativeOrAbsolute));
// Client RenderSettings
xamReportViewer1.RenderSettings = new ClientRenderSettings{
DefinitionUri = new Uri("MyAssembly;component/MyReport.igr", UriKind.Relative)
Miguel
Got it to work by setting the DefinitionUri like this:
urvDefault.RenderSettings.DefinitionUri = New Uri("reporting\" & m_file, System.UriKind.Relative) really dirty, but works. Will clean it in a few ;)
Nope...doesnt work at all...sry :(
Need help, thx
