I really appreciate your fast UI components. Regarding the pivot grid, it looks great and works fine. However, I need to provide the users with ability to drill down on a large hierarchy level. Currently there are some issues that do not allow to achieve that. It would be great, if you consider fixing these issues to provide your customers with the more powerful Pivot Grid. Please see the issues below.
When a hierarchy is added to the Columns or Rows area, the user is able to expand it by clicking the plus icon. When a non-user-hierarchy is expanded, entire level is loaded. This causes a performance issue in case with large hierarchy levels (for example, Date.Date). Maybe there is no need to load entire hierarchy level at this time, because all needed information (including level members) exists in the XMLA Command response.
Also when the XmlaDataSource is built using user hierarchy with specified members, entire user hierarchy will be loaded. Please see the example below.
void MainPage_Loaded(object sender, RoutedEventArgs e)
XmlaDataSource xmlaDataSource = new XmlaDataSource(new XmlaDataProvider(new XmlaConnection(new XmlaConnectionSettings()
//TODO: replace with appropriate URL
ServerUri = new Uri("http://localhost/olap/msmdpump.dll")
xmlaDataSource.Database = XmlaDataSource.GenerateInitialDatabase("Adventure Works DW 2008R2");
xmlaDataSource.Cube = DataSourceBase.GenerateInitialCube("Adventure Works");
xmlaDataSource.Rows = DataSourceBase.GenerateInitialItems("[Date].[Calendar]{[Date].[Calendar].[Date].&[20071116]}");//This will cause XmlaDataSource to load entire Calendar hierarchy
xamPivotGrid.DataSource = xmlaDataSource;
Thank you,
Alexander
UPD:
Hi Todor,
Thanks for your reply. I understand that it will be hard to change the current design. Also I have limited knowledge in XMLA and MDX. Perhaps my issues are related to a specific hierarchy and business needs. The only thing I'd like to mention is that when I use a large hierarchy on columns or rows in the pivot grid in the SSMS, the results are displayed immediately.
Hi
Thanks for your feedback. We will take it in care when you design next version of control
Todor
