I got a weird problem with using XamComboEditor, but I could not reproduce it in a small solution.
1. When I load the XamComboEditor, I set the selectedItem in back end code. The item is selected, but it is not shown in the textbox.
Following is when it is loaded, the first
If I click the dropdown button, it is as following:
2. I am using twoway mode binding. But when I set the selectedItem in the back end code, the dataContext is not updated. And the convertBack function in the converter is never called. But if I change the selectedItem from the browser, the dataContext is updated properly.
I tried to repro it in a simple solution, but I could not repro the problem any more. I am sorry if you could not understand the problem without a demo.
Anyone has an idea?
Thank you very much
Hello ShirleyLiu,
I have already answered to the following forum thread which seems to be for the same question:
http://community.infragistics.com/forums/p/65971/333746.aspx#333746 .
If you don’t mind we can continue our discussion through it. If you have any additional questions on this topic I will be glad to help.
